01-23-2019
03:00
06:02
JuanJoFitbit
01-23-2019
03:00
06:02
JuanJoFitbit
How do I uninstall a clock face and where do I access developer menu?
09-09-2021 14:03
09-09-2021 14:03
Hello everyone. For all of you who are new to the Fitbit community, welcome.
Thanks to all for the efforts to resolve the issue, sharing the solutions and steps you've tried. I understand how you are feeling, your feedback and comments are greatly appreciated. You can find information about changing or uninstalling clock faces in How do I change the clock face on my Fitbit device?
I'll be closing this thread from further comments. If you have more questions, please reach out to our Support team or open a new thread.
See you around.
01-23-2019 06:29
01-23-2019 06:29
Hi, you can uninstall a Clock Face by choosing another Face. Go to Clock Faces, press that and then press "All Clocks" and choose one you like. You will have the least problems when you choose one from Fitbit itself, since some Third Party Faces are not fully compatible with the new Firmware version. How to access the Developer Menu: when you have selected a new clock and pressed "install", wait a few more secs after the installation has finished and the page will be refreshed, showing you "Settings" and "Permissions". Press the last one and enable all items there otherwise the clock might not function well. Pressing Settings lets you customize the clock to your own liking. Good luck!!
01-23-2019 12:55
01-23-2019 12:55
There is contact info for the developer in the clock face info.
As for another info on the face or developer, this would be what the developer has set up.
12-27-2019 07:27
12-27-2019 07:27
This will add another clock face not delete ornunistall one you dont want anymore. Do you know how to delete an installed clock face?
12-27-2019 09:19
12-27-2019 09:19
Yes follow the info above. Choose the watch face you do not want and replace it with one that is liked.
12-27-2019 09:49
12-27-2019 09:49
Hi @Drie , you're probably referring to the Clock Switching facility in the newest Firmware version. Go to Clocks - My Clock and there you will see the installed faces. Press the one you want to remove untill the message pops up "do you want to delete this clock" and press delete. Regards kuzibri
01-03-2020 06:42
01-03-2020 06:42
Hi Drie,
Click on the Clock face you do not want (in the app).
You will see "Settings" and "See all details". Scroll/swipe down beyond that and you will see the button to "Remove clock face".
Kinda annoying that it is hidden like that. Took me forever to find it.
01-04-2020 10:05
01-04-2020 10:05
I tried to look for the setting to remove some of the watch faces I have downloaded but still can't seem to find it. Please help 🙂
01-04-2020 14:38
01-04-2020 14:38
From the My Versa Clock screen
Tap the face that you want removed
Now tap remove
01-05-2020 12:56
01-05-2020 12:56
😞 There is no Remove option on my watch?
01-05-2020 13:54 - edited 01-05-2020 14:01
Hi @DonnyMcJr , do exactly what @Rich_Laue showed you in his post with picture, but if the option is not present on your watch, go to the Fitbit app's CF page (not your watch) and press your particular CF for a short moment and the remove option shows. Regards kuzibri
01-05-2020 18:08
01-05-2020 18:08
01-05-2020 18:30
01-05-2020 18:30
01-08-2020 02:26
01-08-2020 02:26
I have uninstalled a clock face but its still on my watch what do I do to get it off the watch
01-08-2020 11:52
01-08-2020 11:52
Wait for things to update with the next sync, or replace the face with a different one.
Or simply choose the face you want and ignore the unwanted face.
01-22-2020
03:30
06:03
JuanJoFitbit
01-22-2020
03:30
06:03
JuanJoFitbit
Hi jogger,
I tried doing what you said but the clock face I selected doesn't have the option to remove 😔.
Is there any way I can revert back to using my original versa clock face? Thanku
Heya guys, I tried doing what u said to go the the clock face on my app and look under settings for remove clock face but I don't have that option on the clock face I selected as it's a free one.
Also I can't even select a new clock face the option select is all greyed out
please help as I wanna also know can I get back my original versa clock face.
I'm from Sydney Australia. Thanku
Moderator edit: merged reply
01-22-2020 12:55
01-22-2020 12:55
@MischaB how many faces are stored on your versa?
If five, you will need to choose one to exchange.
01-22-2020 12:57 - last edited on 03-09-2020 16:20 by LiliyaFitbit
heya rich,
I only have 2 on my versa clocks.
Thank you for your reply, most appreciated.
Also how can I get back my original versa clock face?
Thank you
Mischa
Moderator edit: format
01-22-2020 14:34
01-22-2020 14:34
Do you remember the name of your original clock face? It would be one of the few created by Fitbit.
02-09-2020 13:14
02-09-2020 13:14
Tried this method, now I have five faces and can't get rid of the two that I don't want. I hope tgey fix this.
