09-11-2018 16:56
09-11-2018 16:56
Hi!
About 40 minutes ago, I dropped my Versa from about 4 feet. The screen isn't cracked or anything but it won't turn on, also the green lights from the sensors are off. I have tried reseting it (with both the normal and the factory method) and nothing...
Does this mean that it won't work again ever? It seems a little harsh since there is no external damage and the fall wasn't that high.
My Fitbit was a present from my boyfriend so any suggestions would be great!
Thanks in advanced!
09-11-2018 19:55
09-11-2018 19:55
This just happened to me not even 40 mins ago. I accidently dropped it off my bed and now the screen is frozen.
09-11-2018 20:33
09-11-2018 20:33
Unfortunately there is nothing more you can do. It wont be covered under waranty unless you purchased the extra protection one.
Helen | Western Australia
09-18-2018 09:31
09-18-2018 09:31
I ended up using the live chat option and they got me a replacement! I live in Mexico and didn't buy the extended warranty so I suggest you try this option 🙂
11-03-2021 02:03
11-03-2021 02:03
Exactly the same for me - it doesn't have any damage signs after a drop, but is just dead. No sensor lights flashing, nothing. And no restart response 😞 Extremely fragile device 😞
Bought Garmin now.
