06-27-2018
16:38
21:00
DavideFitbit
06-27-2018
16:38
21:00
DavideFitbit
I am not able to get pandora to download stations on my Fitbit Versa. Getting very frustrated. Ready to return this as it has issues with syncing to my phone too.
06-27-2018 17:48
06-27-2018 17:48
What have you tried so far?
Not implying anything here but due to lack of info from your post - do you have the paid version of Pandora? The free version does not download music.
This is what worked on my Ionic (which I assume would be similar for the Versa). On the phone app, go to the Ionic settings - Media - then Pandora and make sure settings are good including logon information for Pandora. Put the Versa (Ionic) on the charger and then force a manual sync using the phone app. This should be at the place where you have set up wi-fi as Pandora will only download via wi-fi. Leave it alone for a couple of hours. The download when started should be about 15 minutes per station with a max of 3 stations but it usually takes a little longer depending on the wi-fi.
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
