01-17-2021
12:04
20:47
01-17-2021
12:04
20:47
I want to change the wake screen setting but as I go to settings it's grey and dark and I can't change anything
Got to say very disappointed with versa 3 ☹️
01-17-2021 12:26
01-17-2021 12:26
I expect you are in 'Sleep Mode'; it is under Settings > Quiet Modes. Sleep Mode on intentionally prevents some changes that might cause light at night.
01-17-2021 14:02
01-17-2021 14:02
OK how do I change it?
01-17-2021 14:06
01-17-2021 14:06
You said you already were in Settings. As I said go to Quiet Modes within Settings, then scroll down to Sleep Mode. If it is on, turn it off.
01-18-2021
12:14
07:03
01-18-2021
12:14
07:03
Hi @tiggerno7, welcome to the Forums. @JohnnyRow thanks for helping!
@tiggerno7 thanks for the details provided about this situation with your Versa 3. I suggest trying the instructions provided by our friend @JohnnyRow. Additionally you can find useful information about your watch in this link How do I get started with Fitbit Versa 3?
I'll be around.
05-16-2021 16:59
05-16-2021 16:59
I have the same problems. It is so dim that I can't see the settings unless I shine a flashlight on it. When I see the buttons and press them, nothing happens. It appears to be locked but when I follow all the instructions, nothing helps. I need to be able to SEE the screen.
I just got this yesterday. Super frustrating.
09-03-2022 13:02
09-03-2022 13:02
Same issue! Can only see settings on my phone the device is so dim but also I do t see a sleep mode option. All the options won’t change when I press them. It’s completely unresponsive and frustrating.
09-09-2022 06:12
09-09-2022 06:12
Same issue. I cannot change the setting because they are greyed out.
09-09-2022 07:51 - edited 03-11-2023 09:36
Hi All, you need to go to Quick Settings to remove Sleep mode [swipe watch face to the right] so that normal Settings are again visible.
03-11-2023 09:23
03-11-2023 09:23
JohnnyRow is brilliant! Thanks for pulling me through, sir!
04-13-2023 18:14
04-13-2023 18:14
Your advice allowed me to get my Versa 3 settings working again.
