06-07-2018
12:58
10:22
AlejandraFitbit
06-07-2018
12:58
10:22
AlejandraFitbit
I tried to connect with Bluetooth to Gear IconX and is not pairing. Both have Bluetooth on. On screen is shown pairing, but even after 30 minutes they are not paired yet. I tried many times. Please help me.
Moderator edit: subject
06-08-2018 10:23
06-08-2018 10:23
A warm welcome to the Community @Diapalotas.
Thanks for troubleshooting this by yourself. If you are having issues connecting your Bluetooth headphones with your Versa, I recommend taking a look at the How do I connect Bluetooth audio devices to my Fitbit watch? help article and make sure you are following those instructions.
Hope to hear from you soon.
06-09-2018 13:37
06-09-2018 13:37
06-15-2018 03:12
06-15-2018 03:12
I couldn't conect samsung iconx . I bought fitbit flyer. They work. The other ones are now useless...
09-27-2018 12:36 - edited 09-27-2018 12:36
I'm still waiting for the answer for connecting Samsung Gear IconX to my Versa. What the solution? All troubleshooting has been done. I did the same things as previous people posted. Versa finds the device, says 'Pairing Gear IconX (4405) and continues to have a loading circle moving around. What's up?
09-27-2018 12:43
09-27-2018 12:43
I bought fitbit flyer. I couldn't conect samsung gear
11-07-2018 12:40
11-07-2018 12:40
I am using my Samsung Gear Iconx with my versa. You need to put them in the charging box to connect. Then press and hold the Bluetooth button on the box. Also, make sure to not have your computer or phone Bluetooth on. It might interfere with your initial connection. Hope that helps!
02-22-2019 11:04
02-22-2019 11:04
I have not been successful connecting my Versa to my Samsung Gear IconX. Did you pair yours to a Great IconX 2018? How long did it take to complete pairing?
02-23-2019 00:02
02-23-2019 00:02
02-23-2019 04:41
02-23-2019 04:41
02-23-2019 04:42
02-23-2019 04:42
I was finally able to get IconX 2018 to connect. I removed other bluetooth headphones from my Versa then shutdown my Versa. Once I restarted my Versa the IconX connected right away.
04-09-2019 10:27
04-09-2019 10:27
How's the connection? Mine pair, but the connection is garbage. It has a stable connection to the left earbud, but the right one cuts in and out constantly. My JBL bluetooth earbuds with a cable running between them, however, are perfectly stable. It looks like the Versa simply runs into problems trying to connect to the two earbuds independently.
