08-22-2022
09:01
07:52
AndreaFitbit
08-22-2022
09:01
07:52
AndreaFitbit
I can't swipe from the home screen on my fitbit and I restarted it twice and no luck
08-22-2022 10:36
08-22-2022 10:36
Hello @Versausers
Try changing your clock face and see if that will make a difference. You can go through the Fitbit App to do so: https://help.fitbit.com/articles/en_US/Help_article/2311.htm
🤞 Hopefully this helps. Let me know
08-22-2022 14:28
08-22-2022 14:28
Same, I’ve done multiple reboots, changed my clock face to FitBit ones and no luck. It will still vibrate when I get a text but the only response I can get from it is via the button.
08-23-2022 04:36
08-23-2022 04:36
Hello again @Jenna_fit_bit
If restarting your Versa 2 several times and changing the clock face fails to address the screen from swiping I’d suggest calling Fitbit Customer Service: https://myhelp.fitbit.com/s/support?language=en_US
I hope the can get your screen swiping again and have you up and running again soon.
08-23-2022 08:14
08-23-2022 08:14
This happens to my versa 2 as well. I reset multiple times with no luck.
i gave up and bought the sense gave the versa 2 to my 11yr old and it works again now (face palm)
The only thing I can think that she did is let the battery drain and do a full charge on it to 100%
My versa 2 was two and a half years old.
