I can tap to pay after wallet is uninstalled
So, my wallet app on my phone and my Versa weren't syncing. I had my c edit card on my watch, but clicking on wallet on my phone prompted me to add a card acting as if I didn't have any to begin with.  So I uninstalled the wallet app from my watch. Now holding down the left button still takes me to my credit card, even though I can't access the wallet app from my watch as it's uninstalled. I want to delete the card from my watch but have no idea hoe
6 REPLIES 6
Hi, try restarting your Versa several times by pressing and holding the left and right lower buttons together untill you see the Fitbit logo and release the buttons.
Yes @Razorfin8 uninstalling the wallet app does not remove Fitbit Pay. There really is no reason to have the wallet installed on the Versa.
So how do I remove my card then? On the Android app, it doesn't list any cards, but on the Fitbit, I have a card loaded. All I have is a credit card that I don't use anymore, and my bank isn't supported yet, I want to disable the lockscree .but can't with a card loaded
So you have the Versa to completely lock, or is it set to lock only Fitbit Pay?
My first thought if to go to https://www.fitbit.com/settings/device tap on your tracker, then Fitbit Pay, now deactivate the card of it shows up there.
No do a sync.
That's the problem, the phone app doesn't doesn't show any cards, but my watch is showing a card and nothing gives me the option to delete it
So your saying that Fitbit.com doesn't show the card either?
My thought then would be to sync, if you haven't yet, if that doesn't work i would try a factory reset, then set it up again
