07-24-2018
11:27
18:00
EdsonFitbit
07-24-2018
11:27
18:00
EdsonFitbit
I cannot get my pandora to work on my watch. I have went online and have done exactly what the instructions have told me to do and it will still not connect.
Moderator edit: added label
07-24-2018 11:36
07-24-2018 11:36
I don't have sufficient information from your post so bear with me if you have done some of these already.
1. Pandora downloads will only work with a paid subscription. The free subscription will not download any music.
2. Pandora will only download if the unit is on the charger. It will only download on wi-fi.
3. Go to the phone app and the media options to enter your Pandora account login information. then select the stations you want.
4. Put the Versa on the charger and then manually sync the unit using the phone app. You should be in the location where you have your wi-fi since the download only occurs via wi-fi.
5. This next part can be the hardest. Leave the Versa untouched for about a couple of hours. It takes about 15-20 minutes to download one station. Three stations (the maximum) will take about an hour. It may take some time in the charger for the Pandora app to check in and start the download.
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
