04-06-2019
09:21
18:04
DavideFitbit
04-06-2019
09:21
18:04
DavideFitbit
I couldn't set up my wifi & tried to do the set up without it which is taking forever. Can I go back to the wifi set up page?
04-06-2019 09:48
04-06-2019 09:48
Hi, yes you can. First put your Versa in the charger and connect to your PC. Would do for certainty the same with your phone. Go within the Fitbit app to WiFi settings abd press it. If you do not see your home network's name there, press "Add network" and let Fitbit search and find your home's network. If your network is displayed enter manually the password belonging to your network, e.g. router and press save. Now you will see right next to the name the WiFi icon. If that's white, press it and Fitbit starts connecting to your network. Once this is finished the icon will turn to blue and says connected. To check whether your Versa is also connected, go the settings on your Versa amnd press it. Scroll down to Device Info and press that too. If you see an IP address there, your Versa is also connected to your network. Mind though that this connection only stays active as long as the Versa is in the charger and connected to your PC. This is the result of the fact that the Versa on it's own does not have WiFi, but uses your PC and/or phone as a bridge to connect to WiFi.
BTW, next time you need to repeat the setup, skip during the procedure the WiFi settings by pressing that you will do that later. Good luck!!
