02-01-2019 21:09
02-01-2019 21:09
How do I turn the versa where the screen will come on
02-01-2019 21:35
02-01-2019 21:35
talk to customer service, they are incredibly helpful and did their best to solve the issue. ( I had a similar issue and they couldn't fix it, so under warranty, they are sending me a new versa.) Good luck!!
cheers,
Abby 🙂
02-01-2019 22:42
02-01-2019 22:42
@Judithchrissy2 have you tried rebooting versa several times by pressing and holding the left and bottom right buttons until Fitbit logo appears? If this does not help, try hardware reset using 3 buttons:
You may need to attempt the reset a few times to find the optimal times. Trying holding the buttons longer, as long as it's needed for the vibration to appear.
02-03-2019 10:24 - edited 02-03-2019 10:25
Nice to see that you're digging into the Forums @Judithchrissy2, let me give you a warm welcome to our Community.
Thanks for reaching out. Please confirm if the suggestions given by @Marrrmaduke and @abbyhardy. If that doesn't help we'll be more than glad to request a ticket for this issue. Also check these tips to make sure your Versa is charging properly.
I'll be around.
