12-10-2022 08:58
12-10-2022 08:58
I have 2 Versa2s, and would like to alternate, one for dry land and one for water. Can I have both on my account?
12-10-2022 09:36
12-10-2022 09:36
Hi @Mar1952 short answer is no. You can learn more in this article, which explains it. click to read. Now if you really want to use two different Versa 2 devices, it can be done by swapping them out each time. When you want to use the dry one, sync and remove the wet one from your account and set up the dry one. You'd need to do this each time you swapped out. It's a tad more work, but it's the only way to keep the history from both devices on your one account.
12-10-2022 09:36
12-10-2022 09:36
12-14-2022 06:49
12-14-2022 06:49
Thank you! I thought that might be doable but totally get logging each one as I switch
