12-19-2019 23:36
12-19-2019 23:36
good morning, I did the last software update yesterday, .. and nowadays I switch off my versa for the night so that my battery lasts longer, .. normally I just switched it off in settings, I did this now .. but now the next morning it will not go on anymore, with old software I could press a random button and it went on again, now unfortunately nothing happens anymore and did not switch on anymore, .. not even on the charger, .. gladly your help With Friendly greeting henk
12-20-2019 00:05
12-20-2019 00:05
Press and hold the back and bottom buttons until you see Fitbit logo on screen then let go and it will turn on have just done this myself and it works
Best Answer12-20-2019 03:50
12-20-2019 03:50
What do you mean by hold the back and bottom buttons?
Best Answer12-20-2019 04:07
12-20-2019 04:07
it only worked by pressing all the buttons, .. this did not work immediately, after trying it twice, it only started after releasing all the buttons, .. in the old software it was considerably easier by pressing 1 button for 1 sec pressing no matter which button! .. by the way, I think the entire software has a cheap appearance and would like to go back to the previous software, .. previously when you pressed sports you got a nice picture when starting your activity a random menu where you can choose running, cycling, swimming ... am not happy with it
12-20-2019 19:45
12-20-2019 19:45
Maybe try factory reset in your settings menu it gives you that option
Best Answer12-20-2019 19:50
12-20-2019 19:50
Hold both those buttons until the Fitbit logo comes on screen this takes about 1 or 2 minutes normally so with the Fitbit versa facing you it’s the only button on the left and bottom button on the right once you press and hold in for that long it should reboot the system
Best Answer12-20-2019 21:53
12-20-2019 21:53
I had the same issue too where nothing was turning on my fit bit versa after I thought I had it charging for 2 hours. I think it just died on it's own with battery being low, it's not till I read to try all 3 buttons at the same time that I got the fit bit to start up again. Once it was on it started charging and now I have it up and running. I almost thought it was just not working well since it's been about a year now and everything else I had from fit bit only lasted about 1 year. I think it has to do with the new firm ware they released. Don't let your fit bit drain with a low battery or do not turn it off. Don't even do a factory reset, some one else seems to to have bricked theirs by attempting a factory reset. I hope the buy out from Google doesn't affect anything but hopefully we'll get some resolve soon.
Best Answer12-26-2019 13:46
12-26-2019 13:46
also tried, .. but does not specify which software, .. you install directly with new software 😢
