06-04-2018
10:35
19:22
EdsonFitbit
06-04-2018
10:35
19:22
EdsonFitbit
I've noticed that my set city is gone after every sync that happens. Current location is still there but I don't want to use that setting.
Any idea how to get it locked in for good?
Moderator edit: added label
06-05-2018 09:50
06-05-2018 09:50
Hi @Suureal, welcome aboard to the Fitbit Community! I was reading your selected city for the Weather app doesn't keep the configuration after syncing.
In this scenario, this is an expected behavior. The Weather app by default shows your current location; if you manually add a location that is a duplicate of the Current Location tile, the app will delete the duplicated location every time you sync.
Hope this information helps. See you later!
