I need to keep restarting my Versa in order to sync
ANSWERED
Tried many methods, installing, reinstalling, restarting phone, restarting bluetooth.
The only way I can sync everyday is to restart my Versa everyday.
Anyone know how to solve?
1 BEST ANSWER
Accepted Solutions
Just to be sure, lets check your current status
What phone do you have?
What is your app version?
In the phone Fitbit App
Click on profile photo [top left]
Help & Support
App Version at the top
And what is your watch version?
Device photo [middle left]
Firmware Version at the top
3 REPLIES 3
Help & Support
1) Huawei P30pro
2) 3.37.1
3) 32.72.1.9
Thanks for the feedback, its probably a battery saving issue that disconnects, try
On the phone check battery optimizations
[the options may be different in your version]
  • First go to Settings > Apps & Notification > Special app access
  • Click on Battery optimization
  • Now press the drop down menu [...] and select “All Apps
  • Click on Bluetooth and then select “Don’t optimize
  • Same with Fitbit
  • Next go to Settings > Apps  > Fitbit > Storage
  • Clear cache [not data]
  • and Force stop the Fitbit App
Hope that helps
