08-09-2022
		16:01
		17:34
		08-09-2022
		16:01
		17:34
A couple weeks ago, while in TX, I was outside in the heat and walked often. When I took a shower with the Fitbit on, shortly after, it did turned off and would not respond. I attempted to charge it. It charged, but now, will not hold charge and the "button" to the left will not work.
I bought it brand new Feb 2021. Has it bit the dust?
08-09-2022 20:31
                              08-09-2022 20:31
Hi @LadyBeard the hottest working temperature for these device seems to be 113 f. Pretty sure Texas got really hot. It's possible that your Versa 3 has died, but you should check with customer support to see what advice they have to give you. https://myhelp.fitbit.com/s/support?language=en_US
