05-16-2018 17:28
05-16-2018 17:28
I have had my Versa for 2 weeks, upgrading from a Charge 2 and a Charge before that. As you can see...I am a loyal Fitibit user. But it seems for every one thing I love about my Versa, there is another that I do not love. Updating is a nightmare, and can someone PLEASE tell me how to get calories to show in my workout instead of pace? I do an aerobic workout and have always had calories burned to along with time and HR. I don’t need nor want a pace after my workout. Please advise me how to change this setting, as I have done everything I can think to do!
05-16-2018 18:11
05-16-2018 18:11
I click on the basic workout to start and it shows me calories burned as I go, not pace. I'm not sure which "workout" selection you're using.
05-16-2018 18:18
05-16-2018 18:18
If you use the exercise shortcuts, the settings do allow you to see the calories you burn. With the exercise shortcuts you can see your HR, calories, and time during certain workouts.
05-16-2018 18:23
05-16-2018 18:23
05-16-2018 18:33
05-16-2018 18:33
Are you talking about when you are working out? If so, customize the settings in your activity. So tap on the settings gear after swiping to the exercise activity, then tap customize stats, you can then tap and select for top, middle and bottom what you want to see while working out. Sometimes it resets so I check it before each workout.
The calories burned do show up after the workout in the today app for the 3 most recent workouts.
05-16-2018 18:46 - edited 05-16-2018 18:48
Thank you, yes, I have done all that and thought it was fixed but today after class, I had the same view as before.
05-26-2018 08:01
05-26-2018 08:01
Hi.
Had the same problem and found this in another thread. Worked for me 🙂
Fitbit help people I spoke to had no clue about what I was talking about also!!! At least one staff member somewhere knew what to do!
Try this....hope it works for you too as was so fraustrating.
05-28-2018 10:20
05-28-2018 10:20
05-28-2018 10:41
05-28-2018 10:57
05-28-2018 10:57
The fix didn’t work for long. Gone back to miles and pace again for circuits. Got to be something to do with the Versa as Charge 2 didn’t have a problem.
Fitbit help team are no help at all..... they just don’t get it!!!
05-28-2018 12:04 - edited 05-28-2018 12:06
I just looked at mine too... It shows nothing for calories burned in the log.... My blaze and charge 2 always had the calories burned...
05-28-2018 13:31
05-28-2018 13:31
The ionic has the same problem. Fitbit have known about this for ages and done nothing to correct it. I was like you have the charge 2 and it recorded calories. I then got the ionic and it wouldn't record them. So I returned it and then got the versa hoping this issue would be resolved but it wasn't. Unfortunately the versa had too many other issues that I have had to also return that. I am.now back using the charge 2 . For me this should be one of the easiest things to fix as it works fine with the other older devices.
05-28-2018 19:19
05-28-2018 19:19
This is so disheartening...because this watch isn’t cheap and I wanted to like it. Unfortunately, the dislikes are making it hard to justify the costs. My Charge is still working so I will be sending this Versa back. I went back and forth with Versa and Apple Watch, since I am an Apple user. Because I have always loved Fitbit in the past, I chose the Versa. Now I wish I had spent the extra and gotten the Apple.
05-28-2018 23:30
05-28-2018 23:30
This is the response from @fitbitsupport received:
We apologize for the inconvenience this has caused you, We have no specific timeframe to share on when this issue will be fixed. Rest assured that our team is currently investigating on this issue to ensure this does not continue to happen and can assure you that we’re working to get this fixed as soon as possible. For updates, you can check this Community discussion: https://community.fitbit.com/t5/Ionic/Weight-workout-is-logging-distance/m-p/2355333#M20076. Your continued patience is highly appreciated.
08-28-2018 00:31
08-28-2018 00:31
So ive been bangng on to Fitbit yet again as still not fixed and same old rubbish from Fitbit saying they are actively working on it when evidently they are more inclined to just push out new products with the same problem. It’s probably a very simple fix but they can’t be bothered and it’s been going on for over 12 months!! They are very responsive in Twitter so have a look at my comments with them on there - @timjrowe
