I washed my Fitbit Bertha can
anybody help
5 REPLIES 5
Hi, what exactly do you mean?
I am meant to say I am trying to find my Fitbit and I cannot
Hi, do you have any idea when you last had it/wore it and where that was, cause there is no audible way to find your Versa back as it does not have a microphone. The find my phone solution therefore will not work with the Versa, it also will not vibrate, sorry! Really hope you find your Versa very soon, cause it's a very fine watch.
Hi, @ianradloff, if your problem is that you LOST your Fitbit Versa (not WASHED it) then you may find some of the steps in this help article useful.  There are a couple of Bluetooth finder apps linked that might be able to help you.
I have been able to locate lost Fitbits a couple of times just by checking when my app syncs -- if it syncs, then your Fitbit is nearby.
Unfortunately, if your Fitbit has disappeared from your app that indicates that someone else has found it and attached it to their account.  As long as it still shows up on your app, you know that hasn't happened.
Good luck, and let us know how it goes.
Hi, although this is a very good optionand thanks for this, this make only sense when the phone and Versa are within the BT range, which it's, depending of the BT class, 33 to 150 feet, so really nearby. When he lost it somewhere else, the chance of finding it is almost zero.
