02-03-2019 14:14
02-03-2019 14:14
Fitbit icon remains on watch nothing else. Disconnected and re- booted. Says connected to internet. No change in view.
Best Answer02-03-2019 15:43
02-03-2019 15:43
Hi, contact Customer Support about this issue. They can see whether something is wrong with your battery or not and also if, depending on your warranty, if a replacement is needed.
Best Answer02-03-2019 18:11
02-03-2019 18:11
Welcome top the community @200Atheana have you performed the setup procedure and connected the Versa to your Fitbit account?
If so the Versa is waiting for the Fitbit l firmware if your not seeing the red banner asking to update the tracker, then I suggest doing the setup process again.
How do I set up my Fitbit device?
