07-08-2020 07:47
07-08-2020 07:47
Hi so if im going on a road trip for 2 weeks and my fitbit versa 2 Is on low battery how can I charge it.
07-08-2020 07:55
07-08-2020 07:55
Hi @Lana19 you going to have electricity or a car where you'll be? You can charge it with any usb supported charger unit. If you need to, there are some power banks which can do the trick, but not all of them work. I've charged mine while driving down the road. Will you be able to sync?
07-08-2020 08:00
07-08-2020 08:00
I'm going in a car, does a android phone usb connector will work.
07-08-2020 08:12
07-08-2020 08:12
Hi @Lana19
You might as well as also charge a power bank while you are at home and bring it with you also the charger of the versa. Also try not to use it very often and try to keep the screen on Dim that way the battery can last you more
07-08-2020 08:13
07-08-2020 08:13
Also @Lana19
It should work for the USB cable the end part is all the same
07-08-2020 08:19
07-08-2020 08:19
ok where do I plug the USB cable end
07-08-2020 08:24
07-08-2020 08:24
There should be like a little tab that says USB in your car. Pull it off and you will find a place that you can put your Fitbit cable.
@Lana19
07-08-2020 08:37
07-08-2020 08:37
Ok but I mean on the fitbit versa 2 watch
07-08-2020 09:11
07-08-2020 09:11
It's the new fitbit versa the second one
07-08-2020 09:32
07-08-2020 09:32
@Lana19 not all power banks work to charge these devices and I say that from personal experience. You can charge it up at the wall with any usb supported charger unit - put the Fitbit charger usb part into it and it will work. If you want to charge while driving, you'll need to be sure to have a power plug with a usb connector. Not all cars have built in usb charger ports @A_here
07-08-2020 09:59
07-08-2020 09:59
Nvm lol I just remembered that it's plugged into a USB connector I forgot
07-08-2020 10:24
07-08-2020 10:24
It's ok @Lana19. Getting ready for a trip is work enough. Be safe in your travels.
07-08-2020 10:27
07-08-2020 10:27
Ok I will
