08-14-2023
13:57
03:29
08-14-2023
13:57
03:29
Dear Fitbit: Please do not change the battery charge indicator to Yellow when it is only 75% depleted. For one thing, customers think your watches have a short battery life because the indicator light changes to yellow after just 1 day. Can you please change the light to yellow after 50% battery life is left?
I ruined the back of my Versa 3 by putting it on the charger too often. As soon as I saw Yellow, I connected it to the charger and the pins on the charger dug holes in the back of my watch. After awhile, the holes got so deep that it didn't make a connection to my watch and I couldn't get my Versa 3 to charge.
08-15-2023 03:37 - edited 08-15-2023 03:37
Hi there, @marstar. Thanks for stopping by in the Fitbit Community Forums. We‘re taking your comments and sentiments in regards to our products into consideration.
Please note your Versa 3 does reflect the battery %. To do so, from the clock face, swipe right. The battery level icon is at the top of the screen. When your device's battery is critically low, a low battery icon appears for 3 seconds at the top of the clock face when you turn on the screen. Have you tried using a different clock face? Maybe the clock face you're using does not provide the %.
Please find below some tips for charging your Fitbit device:
Best Answer08-15-2023 11:08
08-15-2023 11:08
