03-25-2019
18:18
07:27
MarcoGFitbit
03-25-2019
18:18
07:27
MarcoGFitbit
My Fitbit HR is so inaccurate. Says my HR is 151 just sitting here. I have not had any issues, but the last 2 days the HR has been all over the chart. I have powered it off and restarted it with no luck.
03-26-2019 07:29
03-26-2019 07:29
Hello @Brandi1087 I hope you're doing well, it's nice to see you around.
I appreciate your participation in the Forums and for sharing your experience with us. Tell me, did you restart your Versa by pressing and holding the Back and Select buttons (left and bottom right) until you see the Fitbit logo on the screen or did you turn it off by going to the Settings app > About > Shutdown?
Now, at this moment, I would like to ask you to go to the Settings app in your watch and tap on Heart Rate to turn it off. Then, restart your Versa again by pressing and holding the Back and Select buttons (left and bottom right) until you see the Fitbit logo on the screen, go back to the Settings app and turn on Heart Rate again.
Monitor it for the next few days and let us know if you see an improvement. Thanks for your patience and understanding, have a great day!
03-29-2019 06:44
03-29-2019 06:44
I have completed a shut down and a factory reset without it being successful. I also un installed and re installed the Fitbit app.
Anything else?
Second time having issues with Fitbit Versa.
03-29-2019 06:47
03-29-2019 06:47
I have completed a shut down and a factory reset. I have also un installed and re installed the fit bit app without being successful.
Anything else?
Second time having issues with Fitbit versa.
03-29-2019 07:23
03-29-2019 07:23
Hi, restart your Versa 4-5 times in a row by pressing and holding the left and right lower buttons together untill you see the Fitbit logo and release the buttons, Usually this solves the problem. Good luck!!
03-29-2019 13:23
03-29-2019 13:23
My Fitbit has been re started so many times. I even left it powered off for a day. Just over it already.
Also have had the HR monitor off for a few days so it dont affect all my other stats.
03-29-2019 13:52
03-29-2019 13:52
Hi, since you tried all the known actions to solve the problem, it's time to contact Customer Support, maybe there is something wrong with the HR sensor. If I really helped you, see my signature. Thanks.
