Since the update I can input my water intake on my versa.
It will sync to my computer, but not to the app on my phone (Samsung S8+)
All the other things do sync, just not the water.
When I add the water on my phone, it does sync to the versa.
Best Answer@McKaos It needs to sync back and forth as you have noticed. Have you tried adding water on your Versa, opening the fitbit app, syncing and then tapping the Water tile in the app? I noticed that it gets refreshed once I go deeper into the water logs by tapping on the tile itself.
Best Answerthat worked. Thanks 🙂 I did have to go one level deeper. After tapping on the water tile on the app, I also had to tap on the Today line.
