01-10-2022
18:02
16:00
01-10-2022
18:02
16:00
I have two questions. I just got a Versa 3.
I do like my Versa 2
1.) Can all my apps and settings be transferred to the new watch?
2.) Is there anyway that I can backup my old settings so that I can reconnect the 2 if I wish? I know that Fitbit cannnot share two currently connected watches of the same model and know it would be disconnecting o e to connect the other.
01-11-2022 04:12 - edited 03-15-2024 17:01
Hi there, @deandsmith. Thanks for stopping by in the Community Forums.
For more detailed information, please see Can I use more than one Fitbit device with the same account?
Note: Please note that all your previous data will remain in your Fitbit app once you set up your Versa 3. As for the apps and settings, not all apps you had on your Versa 2 will be on your Versa 3 and vice versa, this depends on each Fitbit model. For more information, see How do I install and manage apps on my Fitbit device?
I've moved your post to the Versa 3 board for organization purposes.
01-11-2022 04:53
01-11-2022 04:53
Hi @deandsmith - in addition to what @MarreFitbit has provided, the two watches have different features and functionalities.
For instance:
To best get to know things about the Versa 3 have a look in the forums.
01-14-2022 06:29
01-14-2022 06:29
Thank you. i am still a bit confused. After upgrading to my fitbit 3, if I want to go back to my fitbit 2; will it have kept information or will I have to reinstall everything on it too. I want to keep both.
01-14-2022
07:32
04:20
01-14-2022
07:32
04:20
@deandsmith - You can use both, but not at the same time on the same account.
If both watches are still setup there will be nothing to install.
One way to switch is to remove the Versa 3 and then add the Versa 2 to your account which can be tedious. And then repeat the process to go back again.
What may be easier is to one time simply set up another Fitbit account and then have one watch on each account, then you only need logout of one account and login to the other to switch which watch is the active one, of course steps will be counted independently on each account.
Also it would be useful to load the SimpleCheckUp app. This will tell you when you last synced and if its connecting to the Fitbit App, directly on the watch, so you don't need to get your phone out, or do the logout/login to check.
If you do the two account approach, once logged in, go to the home screen without closing the App, a sync popup will appear, click on it and the Fitbit App will take care of connecting the watch to your phone, for the account you are currently using. Easy peasy!
01-14-2022 12:42
01-14-2022 12:42
01-14-2022 12:44
01-14-2022 12:44
@deandsmith - yes,
