05-28-2021 09:21
05-28-2021 09:21
Liebes Fitbit-Team,
seit einigen Tagen funktioniert mein intelligenter Wecker nicht mehr und ich werde "lediglich" zu der eingestellten Uhrzeit geweckt (immer um Punkt 7:00 Uhr, niemals im 30-minütigen Zeitfenster davor).
An was kann das liegen?
Grüße,
Elena
05-28-2021 11:03
                              05-28-2021 11:03
Apart from restart the watch also go to quick settings, pull down once and pull down again on the watch face and click on the 2 white bars and check your Do not disturb setting [and sleep], it is quite easy to enable them without noticing.
 Best Answer05-28-2021 10:35
                              05-28-2021 10:35
Hi Elena
Probably try making sure that you end scheduled sleep mode before the alarm time.
 Best Answer05-28-2021 10:58 - edited 05-28-2021 11:03
Hi Guy_
thanks for your answer. I didn‘t change anything regarding the scheduled sleep mode (it’s been deactivated from
the beginning on).. any other idea? 🙂
 Best Answer05-28-2021 11:03
                              05-28-2021 11:03
 Best Answer05-28-2021 11:08
05-28-2021 11:08
Both disabled. I‘ll try a restart.
 Best Answer05-28-2021 11:14
                              05-28-2021 11:14
Also try a phone restart and have a look at your phone settings in case it has an influence, such as do not disturb on the phone perhaps.
 Best Answer05-29-2021 04:06
05-29-2021 04:06
Restarted the watch twice in the end and now it works again - thanks for your help!
