04-21-2018
06:19
18:01
EdsonFitbit
04-21-2018
06:19
18:01
EdsonFitbit
I’m anxiously awaiting my new Versa and am concerned about the WiFi/connectivity. We don’t have regular internet, we just use our cellular data plan for everything. My phone works as a hotspot, but there’s no router in the house to provide “normal” WiFi. Is a phone hotspot good enough for downloading apps, music, etc on the Versa? Our cellular connection works well and is a strong signal. I’m hoping this won’t be an issue. Anyone in a similar situation?
Moderator edit: added label
04-21-2018 06:27
04-21-2018 06:27
Use your phone as a hot spot. That works best anyway. After the initial setup or to download music. You don’t need WiFi anyway.
04-21-2018 06:27
04-21-2018 06:27
04-21-2018 06:30
04-21-2018 06:30
Awesome! Thank you!
Best Answer04-21-2018 06:32
04-21-2018 06:32
Make sure the WiFi is on 2.4 ghz.
04-21-2018 06:50
04-21-2018 06:50
Hmm I don’t know what that means! I have an iPhone. There doesn’t appear to be an option to change specs for WiFi/hotspot?
