08-25-2019 09:27
08-25-2019 09:27
Hello everyone,
So recently my Fitbit Versa battery life has been lasting around 8 hours or so. I was wondering if anyone else has the same problem.
Or if you had this problem and were able to fix it, what did you do?
08-25-2019 10:56
08-25-2019 10:56
Welcome to the forums!
How old is it? You can try these steps to see if it helps
Also See this thread for charging best practices. If you are not charging it correctly you could be damaging the battery
Wendy | CA | Moto G6 Android
08-25-2019 12:00 - edited 08-25-2019 12:10
Hi Wendy,
I starting wearing my Fitbit Versa on Monday, August 19. I noticed that the battery is only lasting for 8 hours so I did a factory reset, updated to the latest firmware, turned off Bluetooth, notifications, quick view, and automatic screen wake. The only thing I use is the heart rate monitor but I don't think it would affect the battery life too much.
I also charge the Fitbit using my laptop or my iPhone wall adapter. However, it's still dying after 8 hours.
