09-11-2018 06:08 - edited 09-11-2018 06:40
Is it ok to dive into a swimming pool with a depth of just 6 feet while wearing the Versa?
I am not diving from a height-ed diving board but just from the side of the pool.
Is there any chance that water or moisture can enter the watch while diving and damage it ?
I know it is water proof up to 50m depth but nothing mentioned about diving in the user manual.
Best Answer09-11-2018 22:08
09-11-2018 22:08
Yes, we've confirmed with Fitbit.
I learned this in the Ioinic and Versa forums. If you search "diving" or "scuba" or impact on both those forums, there are a number of stories of people whose watches died shortly after diving.
09-11-2018 09:48
09-11-2018 21:33
09-11-2018 21:33
Hi @WavyDavey
Thanks for the information.
Also just wanted to know if your recommendation is based on some past experience of a similar kind or has Fitbit mentioned this to you ?
I also do see a number of posts that do mention that after going for a swim the Versa has stopped working. Maybe it was a dive that impacted the watch and not the actual swimming.
09-12-2018 06:15
09-12-2018 06:15
Thank you @WavyDavey
07-06-2020 09:41
07-06-2020 09:41
I dove off the side of a pool (not diving board) and my versa popped open 😳. I would not recommend.
my versa 2 stopped working yesterday so I grabbed my versa. Now I have two non working fitbits.
