Is it possible to disable Wi-fi on the Versa?
I work in a building that doesn't allow wifi devices if they transmit. Is there a way to disable the wifi?
5 REPLIES 5
Hi @djyoung218,
I don't believe currently there is a way to disable the Wi-Fi. It is automatically turned on and off during firmware updates and music transfer.
There has been a proposed suggestion posted for the Ionic to bring in a Flight Mode to disable Wi-Fi and Bluetooth. If that looks like what you're after, you may want to post a similar suggestion for the Versa at the link below:
Feature Suggestions
Work out...eat... sleep...repeat!
Dave | California
As @WavyDavey says some transfers require WiFi but WiFi only turns on when the tracker is in its charger and charging. At this time the music will update, also the tracker will check to see if any apps need updating .
So while on the arm wifi will be off, and can be verified with a phone.
As for Bluetooth this can not be turned off.
Bluetooth can be turned off. This can be done through settings --> Bluetooth -->Music
@Saad your just turning off the Bluetooth Classic, used for headphones the Bluetooth Low Energy can not be turned off.
@Rich_Laue okay didn't know that. Thanks alot.
