01-27-2019
03:22
11:20
MarcoGFitbit
01-27-2019
03:22
11:20
MarcoGFitbit
I want to add my charge 2 to my Fitbit account but only seem to have the option to replace my versa. Does fitbit not support multi device connection now as there used to be issues.
01-27-2019 04:33 - edited 01-27-2019 04:34
Gail, I can confirm that it is possible. I have both a Versa and Charge 2 on the same active account. The App even syncs both automatically each time I sign on or do a manual sync.
01-27-2019
04:38
11:20
MarcoGFitbit
01-27-2019
04:38
11:20
MarcoGFitbit
Thank you for the confirmation. Can you let me know how this is done please. I only seem to be getting the option to replace the versa with the charge 2
Sent from my Xperia by Sony smartphone
UPDATE:
Thank you for your reply. Could you advise how to do this please as I only seem to have the option to replace the versa with the charge 2
01-27-2019 04:40
01-27-2019 04:40
@SunsetRunner is correct - you can have both on the same account. However if you are trying to do it on an Android phone at the moment it wont let you if thd app is up to date. I think I read somewhere that if you remove the smart watch, then add the tracker, then add the watch back, it will work. But I havent tried it that way. I still had an old app version on my tablet so added the tracker there (I was adding flex 2, but same principal). Once added it works fine. I hope you get it on there. Let me know if it works!
Helen | Western Australia
01-27-2019 04:53
01-27-2019 04:53
01-27-2019 06:44
01-27-2019 06:44
That should work, Gail. I do mine on a computer, not a phone. Until Nelly mentioned it, I didn't know about the Android phone problem. Good Luck!
01-27-2019 07:25
01-27-2019 07:25
01-27-2019 20:05
01-27-2019 20:05
Glad you got it working!
01-27-2019 23:07
01-27-2019 23:07
From what I gather - is supposed to support multiple devices. Not from my experience. I have been switching between my Versa & C3 using a SG Note 9. Every time I install a new device the previous device is automatically deleted. TQ.
@GailAng wrote:I want to add my charge 2 to my Fitbit account but only seem to have the option to replace my versa. Does fitbit not support multi device connection now as there used to be issues.
01-27-2019 23:38
01-27-2019 23:38
@Dlff the app supports multiple devices on one account BUT ONLY ONE with the new OS, which covers Versa, Ionic and Charge 3. I would love to have Versa and Charge 3 on the same account but cant.
02-02-2019 11:25
02-02-2019 11:25
Hello @GailAng and @Dlff, I hope you're doing well, it's nice to see you around. It's great to see you too @NellyG and @SunsetRunner, thanks for all your help.
@GailAng, I appreciate you have come back and let us know your issue has been resolved and you were able to set up your Charge 2 and your Versa on the same account with the help provided by @NellyG and @SunsetRunner.
@Dlff, please note that as mentioned by @NellyG, you can only set up 1 device with Fitbit OS in your account at this moment, that means that in your account you can only have 1 Versa/Ionic/Charge 3 with another device but not two of those at the same time. I understand how important this is for you, which is why I would like to suggest you to check @m_matson's suggested idea to implement this feature in a future update. Feel free to add your vote and comment, this is the best way to make your voice heard.
Thanks for your patience and understanding, if there's anything else we can do for you, please feel free to reply.
