05-11-2018
22:37
04:23
YojanaFitbit
05-11-2018
22:37
04:23
YojanaFitbit
Does beats. Connect with versa via. Bluetooth
05-14-2018 09:01
05-14-2018 09:01
Hello @Anthony060, I hope you're doing well, it's nice to see you around the Fitbit Community.
Thanks for bringing this to my attention. Please note that you can connect your Bluetooth headset to your Fitbit Versa without inconveniences. When you add a new Bluetooth audio device for the first time, make sure both the device and your watch are in pairing mode.
To pair a new Bluetooth audio device, follow the steps below or scroll down to watch the video (English only):
When pairing is complete, a check mark appears on the screen.
I hope this can be helpful, give it a try and keep me posted in case you need anything else.
05-15-2018 08:15
05-16-2018 05:46
05-16-2018 05:46
Hello @Anthony060, I hope you're doing well, thanks for taking the time to reply.
You're very welcome, I hope the previous troubleshooting steps can help you, please keep me updated and let me know if there's anything else I can do for you, I'll be happy to continue assisting you.
Happy stepping!
05-22-2018 16:44
05-22-2018 16:44
Did this work for you? My beats don't show up on my versa .
Thank-you.
Vanessa
05-23-2018 05:36
05-23-2018 05:36
Hello @SunsetRunner, I hope you're doing well, thanks for joining the conversation.
Thanks for bringing this to my attention. If your headset is not being recognized by the Fitbit Versa, please restart it following the manufacturer instructions. Then, try the steps in my previous post to link them again.
I hope this can be helpful, give it a try and let me know the outcome!
05-23-2018 06:15
05-23-2018 06:15
05-23-2018 07:47
05-23-2018 07:47
06-11-2018 05:08
06-11-2018 05:08
Hey,
I restarted my versa several times, yet I can’t link my Beats. The watch keeps on searching But nothing regarding my headphones comes up. I did manage to link a speaker to it.
07-21-2018 17:33
07-21-2018 17:33
I just got my Versa but I’m ready to send it back. I cannot get it to pair with my Beats, not can I figure out how to get music on it. So frustrating.
07-30-2018 15:24
07-30-2018 15:24
Okay I was having the same problem, you have to turn the bluetooth off on your phone. It paired it immediately after I did that. Hope this helps.
08-25-2018 12:14
08-25-2018 12:14
one of the posts says that to get beats to be recognized by versa to restart. I have turned my beats on and off several times and the versa just doesn't see them. Versa searchs but does not find.
Beats works fine with my iphone,
Maybe I misunderstand the concept, but isn't the versa supposed to pair with a bluetooth headphone independent of a phone and use music which has been loaded to the versa (which I have). Then the phone doesn't have to travel with you?
Any idea why my beats won't pair?
thanks
08-25-2018 14:23
08-25-2018 14:23
Hope this helps - I finally figured it out. You have to actually press the PAIR function on your Beats. I can't recall now what that is - pressing the start button five times, or something like that? You can google that - "pairing Beats" - Like you, I thought Versa would just automatically find my Beats if they were turned on. Not the case. SO get your Beats in Pairing mode, and you should be good to go!
08-26-2018 12:11
08-26-2018 12:11
09-10-2018 12:30
09-10-2018 12:30
This worked for me, I was just about to give up! Thanks!
01-10-2019 06:30
01-10-2019 06:30
This was so helpful! Thank you! Holding the power button 4 second starts the pairing on the beats. It was getting a bit frustrating not being able to pair...your post and others on here helped. Thank you again.
01-29-2019 20:37
01-29-2019 20:37
Yea! Thank you this took care of my issue!
02-27-2019 06:38
02-27-2019 06:38
Are you able to control the volume on the headphones? I have this problem with the Versa where my headphones connect, but I cannot control the volume on them. Fitbit Support has told me they are "working on it". That was 5 weeks ago.
02-27-2019 15:55
02-27-2019 15:55
03-16-2019 05:20
03-16-2019 05:20
This was SUCH a big help thanks! Wish this response had been further up in the search results 😂
