04-05-2019
09:50
07:04
JuanJoFitbit
04-05-2019
09:50
07:04
JuanJoFitbit
I've seen a post in which another user drew the conclusion that because of the type of "low energy" blue tooth used by the Versa that the new Samsung Galaxy Buds will not pair. While this is the "accepted solution" to the issue, there was no response by the thread moderation or a fitbit representative. In my own experience my Versa can identify the wireless buds but will not connect, no matter what I've tried. I'd like a fitbit representative to address this issue or conclusively state that this connection cannot occur, if true, thus ending my continued trial and error. thanks.
After 6 months I'm receiving the same response from fitbitsupport. "Hello. We're sorry for the inconvenience and our engineering team is now working to identify a resolution as quickly as possible. We appreciate your patience while we're working on this. Please let us know if there's anything we can do to assist you in the meantime." I doubt there will be a resolution for this issue.
Moderator edit: merged reply
01-25-2020 16:42
01-25-2020 16:42
@Jzizi128 @the way you make them play sound is a process in itself but it works.
1. Open the case and sync both buds.
2. Put one galaxy bud in your ear and close the case.
3. Open the case and sound should come out of the earbud but it will sound garbled.
4. Put the second earbud in your ear, and put the first earbud back in the case
5. Close the case, reopen it again, and now when you put both earbuds in, the buds should sync with eachother just fine and sound quality should be great.
Let me know if this works for you! Sadly it's a pain but hopefully fitbit will fix this problem this year! Best wishes!
Best Answer01-26-2020 06:22
01-26-2020 06:22
Best Answer01-27-2020 02:14
01-27-2020 02:14
Can you walk me though how you were able to connect the two? Tried turning the Bluetooth off as suggested but it still won't pair.
Best Answer01-27-2020 04:13
01-27-2020 04:13
@Shineshine @There is actually no need to turn off bluetooth at all. You only have to disconnect you GB from your phone through the galaxy wearables app. Then it should pair just fine with the watch. In terms of making it play music. Instructions are above. Best wishes!
Best Answer01-27-2020 04:58
01-27-2020 04:58
Best Answer02-06-2020 19:46
02-06-2020 19:46
I successfully paired Galaxy Buds after several failed attempts. I followed the instructions on the Earbuds app. Briefly, go to settings on FB>BLUETOOTH>ADD AUDIO DEVICE>TURN ON EARBUDS>HOLD ON BOTH BUTTONS FOR 3 SECONDS UNTIL PAIRED.
Hope this helps.
Best Answer02-21-2020 18:44
02-21-2020 18:44
This was the solution. Thank goodness I ran across this comment buried in a post. Thank you!
Best Answer02-26-2020 07:52
02-26-2020 07:52
I figured it out!!!! Ok...so...
1) Put on your buds
2) Go to Settings on your Versa 2
3) Go to Bluetooth (Manage Connections)
4) PRESS AND HOLD BOTH OF THE TOUCH PADS ON YOUR BUDS FOR 3 SECONDS (at first there was a noise because I set up my buds to listen to voice commands when I press the left side...but KEEP HOLDING til you hear the beep! It will KEEP beeping. Your buds are now in pairing mode!!!)
5) Press + Audio Device on your Versa 2
6) Connection Complete! How silly was that!!
Best Answer04-02-2020 11:43
04-02-2020 11:43
Thanks duse it worked but it really is a pain in the **ahem** so yea
Best Answer04-08-2020 23:15
04-08-2020 23:15
You are fricken amazing! I bought this Versa earlier on today, spent a few hours trying to get the ear buds to work... took the watch back cause it wouldnt show the ear buds. They replaced it for me with a brand new one. Took it home, tried again and the same thing was happening. Was gettinf extremely frustrated and voilà! Turning the phone bluetooth off is the magic trick. You've made my day! Thank you! thank you! thank you!
Best Answer04-20-2020 12:09
04-20-2020 12:09
Worked like a charm. Thanks.
Best Answer04-25-2020 07:52
04-25-2020 07:52
Sorry but it didn't work for me. Thx
Best Answer04-25-2020 08:55
04-25-2020 08:55
Mine are now connected. Make sure you're not using 5g wifi. My problem now is getting sound. Sometimes yes, sometimes no. Seems to work if I connect the buds first then start Deezer. But, if I pause it, I lose the sound.
Best Answer04-25-2020 09:28
04-25-2020 09:28
Best Answer04-25-2020 09:55
04-25-2020 09:55
Best Answer04-25-2020 20:29
04-30-2020 14:11 - edited 04-30-2020 14:15
Thank you ! This worked now i can heard my music clearly BUT i cannot use my GB controls except volume, no pause, nxt song, repeat ...😏 .
Any Ideas how can I fix this?
Best Answer05-07-2020 10:39
05-07-2020 10:39
Well after being on fitbit for almost 2 years I finally bit the bullet and switched to a Galaxy watch active 2. My Versa randomly died and wouldn't turn back on after a reset and it was out of warranty. I got a Versa 2 but only kept it for a week before returning it.
The fact that I couldn't reliably pair my galaxy buds to it, coupled with what I found out about the connected GPS doing weird data manipulation (https://www.reddit.com/r/fitbit/comments/dtj9ln/why_you_shouldnt_trust_connected_gps/) I made the switch.
I must say that aside from the shorter battery life the galaxy watch is so much better. What I lose in the data from Fitbit compared to samsung health I gain a fully featured smartwatch with built in gps that flawlessly connects to and plays music with my earbuds. And after updates that fixed GPS accuracy it all seems good.
Best Answer05-07-2020 16:06
05-07-2020 16:06
Best Answer05-13-2020 21:11
05-13-2020 21:11
Thank you so so much!!! I was seriously considering returning my brand new Versa 2 and purchasing a Samsung Active watch.
