Is there a way to set up a group?-Versa
Is there a way to set up a group and then invite other fit bit users to that group.  I have started weight watchers and I have found out that there are a lot of people on weigh watchers that have fit bits.  It would be so awesome if we had a group for weight watchers
Moderator edit: added label
2 REPLIES 2
Hi @SunsetRunner
You can start your own group or check to see if there is an existing group here - click to go there
When you set up the group, you might want to post it in the Get Moving or Be Inspired forum area.
Keep on stepping!
Stepping in the U.S.A. since September 2013. Android 14
How do you move it to that other group
Sent from Mail for Windows 10
