02-26-2019 10:01
02-26-2019 10:01
Hi there,
I'm training for a 10k and trying to run 5 mins and walk 1 min. Someone at one of the run clubs said that there's a way on fitbit to set up this timing (maybe through a third party app?) so that the fitbit will vibrate when each interval is done. Does anyone know how to do this on the versa?
I've tried downloading both Tabata Timer and Run Walk apps and neither works.
Any suggestions???
02-26-2019 12:37 - edited 03-02-2019 20:14
@AshF03 You can use Interval Workout on your Versa. If it does not show in your Exercise app, you will need to add it as a shortcut. Open Fitbit app, tap on the Versa icon, scroll down to Exercise Shortcuts, tap a plus sign in the top right corner and add Interval Workout. If you cannot see + sign, you need to delete one of the exercise shortcuts as you can have only 7. Please take a look at this help article to learn more about setting the intervals of your workout.
