09-28-2018 13:03
09-28-2018 13:03
09-29-2018 10:52
09-29-2018 10:52
Hey @umeshk! It is great to see you around! I'd like you to take into consideration if from some time ago, maybe some factors are affecting your heart rate, such as movement, temperature, humidity, stress level, physical body position, caffeine intake, and medication use are just a few things that can affect your heart rate. Different medical conditions and medications can impact your heart rate. Consult your doctor before starting an exercise routine. If this is not the case, then I'd like you to try the following:
- Make sure that you are correctly wearing it
- Turn ON/OFF the heart rate on the settings of your Versa
Give it a try and let me know how it goes!
