04-26-2018
20:55
09:02
HeydyF
04-26-2018
20:55
09:02
HeydyF
so i got my versa today. it's a love hate relationship.
getting notifications, just not vibrating to let me know.
checked all the settings and it is all set correctly.
active minutes not logging which is messing with my calories i can eat for the day
250 per minute is also not registering even though i did walk my 250 all my hours. no reminders to walk.
delay when i send a test call.
i prefer to keep my phone on mute at work and recieve my notifications on my fitbit, but it doesn't do that anymore.
come on fitbit, get it together.
Best Answer04-27-2018 08:59
04-27-2018 08:59
Hey @XmenMommy, let me give you a warm welcome to the Community! Don't you worry, let me give you a hand on this.
Fitbit devices calculate active minutes using metabolic equivalents (METs). METs help measure the energy expenditure of various activities. Because they do so in a comparable way among persons of different weights, METs are widely used as indicators for exercise intensity. For example, a MET of 1 indicates a body at rest. Fitbit devices estimate your MET value in any given minute by calculating the intensity of your activity.
You earn active minutes for activities at or above about 3 METs. To stay in line with the Center for Disease Control's (CDC’s) “10 minutes at a time is fine” concept, minutes are only awarded after 10 minutes of continuous moderate-to-intense activity. You can view the CDC’s recommendations on the CDC website.
In addition for active minutes as well, remember that heart rate Fitbit, like your Versa in this case, uses that information to track them, so I'd like you to review the wearing tips in this help article 'cause perhaps you are not wearing your Versa correctly while you are exercising and it is not well tracking your BPM.
Keep me posted!
Best Answer04-27-2018 09:06
04-27-2018 09:06
Best Answer04-27-2018 16:37
04-27-2018 16:37
i think the versa is having the issue apple had with their watch. i switched my fitbit to my other arm, the one without a tattoo and my heartrate is measuring now which will probably fix my active minutes issue. the other issues are still there
Best Answer04-27-2018 16:45
04-27-2018 16:45
I think the tattoo thing may have fixed all these issues. has anyone else had this issue. also, is fitbit working on the silent issue. i hate having my phone on vibrate.
