05-05-2018 08:08
05-05-2018 08:08
I was able to successfully do blue tooth pairing on my phone for Fitbit Flyer, but when I try and pair my Versa with Fitbit Flyer the Versa watch says that it is searching for an audio device, however, when it is done searching it says "No devices found" even though I have my Flyer turned on in order for it to pair.
Additionally, I was trying to set up my Versa with Fitbit Connect after being prompted in my Fitbit Mobile app to use the Fitbit software on my computer to transfer and manage my personal music (I downloaded the Fitbit desktop application for my MacBook Pro). The issue though is that when I open the Fitbit Connect desktop application on my MacBook Pro and I go to select my Fitbit device it says that Versa is for mobile set up only. Not sure what that means and not sure how I got about doing a mobile set up for Versa so that I can transfer and manage my music directly on the Versa device.
Anyone else having those two same issues?
05-05-2018 08:48
05-05-2018 08:48
Okay, so I was able to resolve one of my two issues. The issue I was able to resolve on my own was FINALLY being able to pair my Versa with Fitbit Flyer. The only issue that I still seem unable to resolve is figuring out how to manage and transfer music to the Versa device itself. As I said, I downloaded the Fitbit Connect desktop app for my MacBook Pro, but when going through the set up instructions it doesn't show the Versa and shows at the bottom with an * a message that says *Mobile set up only: Ionic, Versa, Aria 2, Ace.
Anyone have success in doing that mobile set up only in order to manage and transfer music directly to the Versa device since in the Fitbit Mobile app is says to use the Fitbit software on the computer to transfer and manage personal music?
05-05-2018 08:48
05-05-2018 08:48
05-05-2018 13:50
05-05-2018 13:50
How did you get them to connect. I'm getting the same error
05-15-2018 19:33
05-15-2018 19:33
Apologies for the delay in responding. I think what I did was I briefly turned off the Blue Tooth Feature on my cell phone, then went to settings on the Versa and then selected the Blue Tooth Connection Options to pair the Flyer to the Versa (make sure the Flyer is on when you try and pair it to the watch). I then turned the Blue Tooth feature from my phone back on in order to have the Versa be connected to more than one device.
