06-27-2020
14:17
22:25
RicardoFitbit
06-27-2020
14:17
22:25
RicardoFitbit
I recently bought an A71 and I seem to have glitches with my versa 2..Fit bit..Please allows A71 to be a compatible device. It's an amazing phone!!!
06-27-2020 22:14
06-27-2020 22:14
Hi @Mandy29pillay, welcome to the Community Forums!
Thanks for bringing this to our attention and for the details that were shared in your post. To better assist you with your concern, can you please elaborate on the issue you're experiencing with the Samsung Galaxy A71? In which way does it glitches with your Versa 2? Are you having connection difficulties or issues with the app?
Looking forward to your reply.
08-02-2020 19:41
08-02-2020 19:41
Are you still having problems with compatibility with your A71? I was thinking of purchasing that phone but don't want to if it won't work with my Versa 2.
08-18-2020 07:22
08-18-2020 07:22
I also have s samsung a71 and a versa 2. I have spent a long time with on line help with fitbit with my syncing problem, only to be told my devices aren't compatible. To sync the versa, I have to shut it down n restart it. Its very annoying. I agree, its a great phone but the versa problem (and fact that it doesn't charge wirelessly) make it annoying. My daughter has same phone n versa 2 n she says she has no problems
12-12-2020 22:18
12-12-2020 22:18
Mine keeps disconnecting. It's so frustrating. Only way to get it to sync is to uninstall app and hard boot Versa2 after reinstall. It's getting very frustrating doing it so often.
