12-29-2018
14:33
04:31
YojanaFitbit
12-29-2018
14:33
04:31
YojanaFitbit
I received a versa for Christmas along with some awesome wireless earbuds fro Jabra. The problem is that my watch is not recognizing them as a bluetooth audio device. I have the Jabra elite 65t. Please tell me this will be fixed.
01-01-2019 20:15 - edited 01-30-2019 11:21
@valererene Have you paired the Jabra with any other device before pairing with Versa? I am not sure about that particular model but most of the buds allow only for pairing with one device. Reset Jabra, unpair it from your phone, reboot Versa by pressing and holding the left and bottom right buttons until Fitbit logo flashes, put the Jabra in the pairing mode and try connecting with Versa again. Check this article if you need help on how.
01-02-2019 09:50
01-02-2019 09:50
Hey @valererene, it is great to see new faces around! Some third party headphones are giving connectivity issues, and our team is aware of this. Don't you worry 'cause they are already working on this so the users can use their Bluetooth headphones without inconveniences.
Either way, you can try the instructions that @Marrrmaduke posted above. 😉
Have a nice day!
01-30-2019 05:47
01-30-2019 05:47
Has the issue with Jabra earbuds not syncing with Versa been resolved? Every time I try to pair, Versa finds the Jabra earbuds, but then it continuously says “Pairing Jabra Elite Active 65t” but never connects. I have reset the Versa. I have reset the earphones. When I first got the earphones in Nov, they paired up for a few days. Since then, they have not. I got the Versa so I could use wireless headphones and listen to music on my Fitbit without having my phone in the gym. It did pair up with my previous Bluetooth headphones but has had problems with Jabra. This is very frustrating!
01-30-2019 06:36
01-30-2019 06:36
Hello @Mimisue, welcome aboard and thanks for trying a few tips to connect your Jabra earbuds with your Versa. I can't tell you when the third-party headphones will no longer have issues to connect with the Fitbit Versa, so in the meantime, I can only ask you to be patient while our team still working on this.
Let me know if you have further questions or comments!
01-30-2019 07:18
01-30-2019 07:18
What I had to do was unsync my phone with my jabras, turn the jabra’s off and make sure your phone Bluetooth was off so it would find the jabra’s and then they would find my Versa. I hope that they add amazon music so I can resend my Versa with my earbuds but for now I just carry my phone with me.
Hope that helps and makes since.
01-30-2019 11:44
01-30-2019 11:44
Hey @valererene, I hope you are doin' fine! Thanks for sharing these tips. Sounds great that your Jabra are working with your Versa. 😉 They might help other users with the same issue, to solve it. If you have further questions or comments, let me know.
I'll be around!
01-30-2019 16:14
01-30-2019 16:14
01-30-2019 16:17
01-30-2019 16:17
@Mimisue do you have any other audio devices connected to your Versa?
01-30-2019 16:17
01-30-2019 16:17
01-30-2019 16:23
01-30-2019 16:23
02-01-2019 07:02
02-01-2019 07:02
Hey @Mimisue, I hope you are doin' fine! I appreciate the tips you have tried so far to fix this. Well, as I've mentioned before, since the Jabra are third-party headphones, you might experience connectivity issues between it and your Versa. But our team is working towards a solution so I will ask you to be patient while this is getting resolved.
Let me know if you have further questions!
02-01-2019 17:39
02-01-2019 17:39
02-02-2019 09:49
02-02-2019 09:49
Thanks for the update @Mimisue. Is great to read that your Jabra Elite Active 65t are working with your Versa, even though you have to be disconnect them and pair them again. Those are the issues that some users are experiencing with their third-party headphones. I will ask you to be patient while this get resolved. 😉
Let me know if you have further comments!
02-15-2019 18:50
02-15-2019 18:50
Hi
The problem is still persisting as i have tried restarting the versa many times have resetted my jabra multiple times but still the issue exists where im unable to pair my jabra and versa. This issue started to occur after my versa switched off being connected to jabra and then when i swtiched on the versa again...it doesn't pair back to the jabra. its been a week and half since im trying to pair both of them. Please help me resolve this issue.
02-15-2019 20:23
02-15-2019 20:23
@shivaram Have you tried:
02-16-2019 14:26
02-16-2019 14:26
02-17-2019 15:17
02-17-2019 15:17
02-17-2019 20:06
02-17-2019 20:06
I had the same problem as of yesterday. Very similar issues both of us are having.
02-17-2019 20:08
02-17-2019 20:08
Yes Yes Yes have tired even resetting factory settings removed from all my devices yesterday and then readded my jabra it got connected and then today its not connecting again where its not paired to any other devices.
