Lifting wrist does not always turn on clock face. Other options?
I have read the existing posts and I am still not seeing my clock face display. Can someone confirm that a simple wrist flip is all that's required?  Is left button the other option?
35 REPLIES 35
You should be able to see your clock face when you flip your wrist. Did you check to see if your quick view is turned on?
Hold the left button until it vibrates and ensure that Screen Wake is turned ON.
KC | Texas
One, Charge HR, Charge 2, Versa | Galaxy S9 Plus
How do you turn on screen wake? It is set to auto - is that what you means?
Is "Auto" the same as "on"?
had the same issue  try this bend your elbow so your forearm is straight up and down then flip your wrist   always works for me
Thanks! I had shut my quick view off by mistake...whew
Your quick view should be turned on. Yours may be on manual.
Have quick view on Auto and still will not work is there anything else I can do?
I am having same issue nothing seems to work!
I haven’t had that issue. You could try a reboot or set your settings to stay on
Sent from my iPhone
To turn on your clock face you could press the button on the left side or you can double tap the screen.
Android and iPhone 6s. Versa, Flex 2, and Zip
Finally!   have been going crazy trying to figure out why mine suddenly won't wake when I raise my wrist and this was the problem for me.  Thank you!!
Glad I could help
Sent from my iPhone
Thank you for this!!! I was hecking my setting on the Fitbit app and the settings on the watch itself but couldn’t figure it out until I saw this post about holding the left button. I have a 1 yr old and he’s always playing with my versa and I was sure he had messed up something because I wasn’t seeing my display when I would flip my wrist.
Sometimes I could bring my hand all the way up to my face the screen is just black. It doesn't turn on even though screen wake is on. I have to forcefully turn my wrist in order for it to turn on.
When anything fails, try a soft reset
Sent from my iPhone
I've been having the same problem for the last few weeks..... really frustrating!
Thank you. It’s working properly now!
I have tired the way that you described and still no luck am getting frustrated, watch is only 2 says old, it worked yesterday so what is up
