Lifting wrist does not always turn on clock face. Other options?
I have read the existing posts and I am still not seeing my clock face display. Can someone confirm that a simple wrist flip is all that's required?  Is left button the other option?
35 REPLIES 35
A soft reset might help. Hold Left and lower right buttons until the Fitbit logo appears and see if that works
Sent from my iPhone
Yes that did it thanks just trying to figure a lot of stuff out. Can not get my music from my IPhone to sync it says get next to the router well I am sitting next to computer, funny thing is my phone is connected no problem
Sent from my iPhone
It worked thanks so much.  Still can not get my iPhone 7 to sync to my music , have tried and tried am sitting right next to the computer and the router makes no sense
That I can’t help u with as I don’t use mine for that, sorry
Sent from my iPhone
Thanks any way I can not even find a phone number for help and u would think that paying $200.00 they would respond
Sent from my iPhone
You may have already solved your issue, but the customer service number is in the phone app
No longer have this Versa returned it yesterday after three hrs on phone with customer service who do not know what they r doing I said enough is enough ..AWFUL PRODUCT
Sent from my iPhone
Wow, sorry to hear that.  Hope I don't start having issues with mine bc I really like mine. What are you going to replace it with? Good luck.
The fit bit I had from two years ago . I loved it a lot but the point of getting it was for the music that I could import from my iPhone. I could not even use the music they offered I asked them to send me a replacement and the answer was it would months to one. My little does a lot and till get a better idea I will just rely on that one
Sent from my iPhone
Sent via the Samsung Galaxy S7 edge, an AT&T 4G LTE smartphone
I agree!
Sent from my iPhone
Thank you..  That worked..   Smiley Happy
Hold the left button until it vibrates and then you can change the setting from "manual" to auto
The same thing happens to me when I am biking, even though I use the same gestures as I always do when I am not biking. Is it because the exercise app interferes with the accelerometer or something?
Thanks for the quick fix!
Thanks !
