01-02-2019 09:10
01-02-2019 09:10
This started last night when I was sleeping. It's a very very faint light vibrations that happens very randomly. I've rebooted it a few times. I've also changed the clock face (as I thought it might be that), and I am using a FitBit developed clock face.
Thanks!
Best Answer01-04-2019 16:27
01-04-2019 16:27
@hoki You can try toggling the vibration settings on your Versa (in the Settings app), but if you see no improvement, you might have to perform a factory reset (restoring your tracker to factory defaults). This will wipe your Versa, so please sync first. You will also need to delete your tracker from the Fitbit account (in the Fitbit mobile app) and your Paired Devices list in your phone Bluetooth settings. You can perform factory reset by going to Settings on your Versa, scrolling down to About and tapping Factory Reset. Once Versa resets to factory defaults, you will need to set it up again by adding it as a new device in the Fitbit mobile app. Good luck!
