07-16-2018
17:31
11:42
DavideFitbit
07-16-2018
17:31
11:42
DavideFitbit
I have the new Versa.
Can you lock it so if any of the buttons are pressed, it does nothing?
When i wear it was my boxing gloves some buttons are pressed and the stop watch has started or something else has happened.
07-16-2018 19:30 - edited 07-16-2018 20:45
Hello @Jess84
I know you need a password for Fitbit pay, not sure if you can set it up to wake it up with a password.
Have a look in the manual.
Here is a copy of the Versa manual.
https://staticcs.fitbit.com/content/assets/help/manuals/manual_versa_en_US.pdf
ALAN | VAN,B.C. Canada Community Council Member
Versa, Charge, Charge HR, Ionic, Ace, Aria 2 scale, Flyer headphones - iOS
Click here Fitbit help for more solutions
Best Answer07-16-2018 20:34
07-16-2018 20:34
Thank you
It worked ![]()
Set up device lock Device lock is available on watches that support Fitbit Pay. To help keep your watch secure, turn on device lock in the Fitbit app, which prompts you to enter a personal 4-digit PIN code to unlock your watch. Device lock is turned on automatically when you set up Fitbit Pay to make contactless payments from your watch. If you choose not to use Fitbit Pay, device lock is optional.
Best Answer07-16-2018 20:43
07-16-2018 20:43
Right on, @Jess84
You can mark this as accept as solution for others to see
