01-03-2019 15:49
01-03-2019 15:49
Hi Everyone,
My Vsera was locked yesterday and the watch was also removed from my iso app. I have tried many ways to reset it however it’s always failed. Appreciate if someone could help.
Best Answer01-04-2019 00:08
01-04-2019 00:08
Hi @C.X
Have you tried the following?
First go into your phones Bluetooth settings and unpair the Versa from there.
Does the phone find your Versa and ask for the code that's on the screen?
Best Answer01-04-2019 06:11
01-04-2019 06:11
Hi Nathan,
Thank you very much for your help.
I tried to re-pair the watch and apps from both my iPhone and win10 system however I couldn't see the paring codes from the watch due to the screen was covered by a notification of ' Unlock with Your Phone'.
I don't know how to pair my locked versa back to the fitbit app? anyway to reset the versa back to factory mode?
Best Answer01-04-2019 08:56
01-04-2019 08:56
@C.X wrote:I don't know how to pair my locked versa back to the fitbit app? anyway to reset the versa back to factory mode?
Yes you certainly can by following the hardware (button method) factory reset steps below.
On the watch, hold all three buttons for about twelve seconds. This will trigger the 2-button hardware restart after about eight seconds.
- When the Fitbit logo appears, then disappears, release the bottom right button, whilst continuing to hold the left and top right buttons until you feel a strong vibration. This indicates the factory reset was initiated.
- This process may take several seconds, and eventually, the Fitbit logo appears and the device boots and displays go to Fitbit.com/setup.
- If you fail to release the bottom right button in time or otherwise don't follow the procedure precisely, the Fitbit logo reappears quickly and boots without factory reset.
Best Answer01-05-2019 04:56
01-05-2019 04:56
I tried it many times in the pas few days which it doesn't work instead of rebooting the watch. it's till locked. 😞
Best Answer01-11-2019 05:36
01-11-2019 05:36
Sorry, it doesn’t work. I cannot pair the watch and phone as the watch screen is always blocked.
Best Answer01-11-2019 06:58
01-11-2019 06:58
yes Nathan, the phone could find Versa and asks for the codes however I cannot see the codes as the screen of versa has been locked. any more suggestions. Thanks
Best Answer01-11-2019 09:14
01-11-2019 09:14
Try going over the steps again for the 3 button factory reset. If you don't follow the steps exactly it won't work. If you are still seeing the lock screen after the reset it's possible you're not performing the reset properly.
