04-15-2018 22:02
04-15-2018 22:02
When I had my Blaze I would select exercise/workout directly on my phone. On the Fitbit app it would display the activity and stats. It always showed calories burned. That’s since been replaced with ‘pace’... I hate that! I’m not doing anything that would register for pace. I’m doing at home workouts! I’d much rather see calories burned instead of pace. My gps is off. It’s srill happening. The only way that I’ve found to avoid that is to workout without selecting it on my Versa. The issue with that is then it doesn’t keep the accurate time for my workout. Is this happening to anyone else? Any ideas how to fix it?
04-16-2018 01:25
04-16-2018 01:25
@HeathGetsFitIt's probably the same issue I posted yesterday in the Dashboard forum at this link.. The data is there. But in my case I rename the Workouts to achieve the results..
@HeathGetsFit wrote:When I had my Blaze I would select exercise/workout directly on my phone. On the Fitbit app it would display the activity and stats. It always showed calories burned. That’s since been replaced with ‘pace’... I hate that! I’m not doing anything that would register for pace. I’m doing at home workouts! I’d much rather see calories burned instead of pace. My gps is off. It’s srill happening. The only way that I’ve found to avoid that is to workout without selecting it on my Versa. The issue with that is then it doesn’t keep the accurate time for my workout. Is this happening to anyone else? Any ideas how to fix it?
04-17-2018 09:37
04-17-2018 09:37
Yeah I’m having this issue too! Worked fine on the blaze, do we know why this has changed?
04-17-2018 10:01
04-17-2018 10:01
No idea! But we aren’t alone. I posted in a Facebook Fitbit Versa group and several other users commented saying it was happening to them also! I hope it gets addressed/corrected soon!
04-19-2018 18:25
04-19-2018 18:25
I’m so glad I found this because I was just about to start a new discussion asking the same question. I hate this also!!!
someone please give me a solution to my OCD problem lol
04-19-2018 18:33
04-19-2018 18:33
Hi all,
This behavior has been noticed with the Ionic also. Please see the solution in this thread for a workaround. Fitbit is investigating this.
05-26-2018 07:54
05-26-2018 07:54
Had the same problem and found this in another thread. Worked for me 🙂
Thanks for stopping by @kiti, hope you're doing good! Hmmmm.... this is very strange my friend. I'd recommend the following:
Give this a go and let me know if the distance is still appearing after syncing your workout!
05-29-2018 06:29
05-29-2018 06:29
This does not work on the versa. Still getting pace instead of calories when selecting workout.
05-29-2018 06:35
05-29-2018 06:35
Yes you’re right. The ‘fix’ worked for me for one activity after completing the steps but then reverts back to the wrong diplated stats.
06-07-2018 11:28
06-07-2018 11:28
I've discovered that if I don't manually track my workout and I just let my Versa figure it out, it will sync to the app and show the calories burned and the length of workout instead of pace and distance. Just edit the time frame and category of the workout afterwards.
Hope this helps!! At least this doesn't involve constantly having to delete the app or reboot your phone.
06-21-2018 19:13
06-21-2018 19:13
Did you ever find a solution to this problem?
06-21-2018 22:55
06-21-2018 22:55
I’ve found nothing to sort the issue and FItbit not really interested as just come back with the usual unhelpful responses.
06-22-2018 06:02
06-22-2018 06:02
10-09-2018 17:51
10-09-2018 17:51
This is so bogus. I tried the steps suggested to no avail. Fix this!! It’s pissing me off!
04-18-2019 07:46 - edited 04-18-2019 07:56
Ok I have an Ionic and I've been asking about this for years now. Ever since I owned my Charge 2 I've had to enter my workout manually in order to display the Calories burned.I just tried doing the steps below and so far it worked for me... I will keep everyone posted.
04-18-2019 12:54
04-18-2019 12:54
Ok after doing a workout (using the "Workout" category) it worked and showed Calories burned, but the minute I changed the name of the workout to a custom one that I use ( I created one called HIIT Training) it switched back to show my pace...UGH!!!!!! WHY FITBIT??? WHY????
05-03-2019 20:15
05-03-2019 20:15
This is exactly what I trying to solve. For the custom activities it changes from min & Cal to Km & Pace.
It is useless
06-28-2019 11:23
06-28-2019 11:23
I am trying to get pace on my Versa
04-25-2020 12:18
04-25-2020 12:18
Did you ever find a fix? Hate that it does this!
04-25-2020 12:19
04-25-2020 12:19
Did you ever find a fix? I have this issue too and hate that I have to go through my fitness pal to fix it.
