05-25-2024 13:51
05-25-2024 13:51
I charged my Versa 2 today, getting it up to 99% power. A few hours later, it wouldn't turn on. When I attached to power cable, the power was down to 4%. The watch has not come into contact with water. Has anyone else seen this happen and does anyone know why. Thanks.
05-25-2024 13:56
05-25-2024 17:11
05-25-2024 17:11
I'm long past the warranty, and the problem happens infrequently. Not sure if something external is causing the issue.
05-25-2024 21:19
05-25-2024 21:19
@basenji - it is unlikely to be software but try changing clock face and also try holding the watch button for 10 seconds till it blanks or vibrates and wait for the logo to appear and for it to start.
If they don't resolve it a factory reset (not without risk) might but it could just be an intermittent hardware fault and nothing will fix that.
05-31-2024 16:23
05-31-2024 16:23
There's several threads about this exact same issue. You should search for them. I can almost guarantee it's not a problem with your watch. The posts and comments are definitely worth a read.
