10-22-2018 15:00
10-22-2018 15:00
Hello. I’m Beyond frustrated. I took my versa off to have a shower. I know it water proof but done need body soap all over it. I forgot it in a locker I was renting. It’s gone.
Heres what im wondering. Is this useless to someone else? Is it locked to me / my account? Or can someone just her factory reset and it’s theirs?
Best Answer10-22-2018 20:14
10-22-2018 20:14
Well its useless unless they have a charger. But otherwise they can use it. They just need to set up an account
Please check the gyms lost and found. Maybe it was turned in. I sure hope so
Wendy | CA | Moto G6 Android
10-22-2018 22:20
10-22-2018 22:20
Or you might want to try to find it with some Bluetooth tracking app in case it fell done somewhere and nobody noticed. But honestly I wouldn't hold my breath.
10-25-2018 14:21
10-25-2018 14:21
Hi @Matclar, thanks for reaching out the Forums, sorry about what happened to your Versa. ![]()
Try following @WendyB and @Giampi71 suggestions. When a tracker is lost in a public place, it is very difficult to know, if the person that finds it is going to return it. If you don't find it, it's best to contact Customer Support to report it and see the options that they can give you. I can give you a hand with that if you need it, please let me know the outcome of your case.
Good luck, I hope you can get it back! ![]()
