Lost my Versa Lite
ANSWERED
So I lost my turn it versa lite. Is there anyway I can track it or something.
1 BEST ANSWER
Accepted Solutions
Hello there @Fiji_water123, welcome to the Community Forums.
As @Odyssey13 has mentioned, if you lose your Fitbit device, try the following tips to find it:
  • Check your dashboard to see the last time your device synced. If it synced recently, it's likely within range of your phone.
  • If you use a clip-on device, check the clothes you were most recently wearing.
  • Take your phone to the area where you think you lost your device and try to sync it. If your device syncs, it's nearby. For more information about how to sync your device, see How do Fitbit devices sync their data?
  • Try using a Bluetooth locator app to help you find your device. For iPhone, try LightBlue Explorer. For Android, try Bluetooth Finder.
2 REPLIES 2
Hi @Fiji_water123  no way to track it, but it will sync if you're within range, about 25 feet.
Stepping in the U.S.A. since September 2013. Android 14
