03-22-2020 02:12
03-22-2020 02:12
Llost my phone and got a new one but my fitbit versa 2 says unlock with phone how do I do this
03-22-2020 02:16
03-22-2020 02:16
Assuming you have downloaded the app on your new phone (and logged in to your account) then:
03-22-2020 02:27
03-22-2020 02:27
It's a different phone it doesn't have it
Best Answer03-22-2020 02:37
03-22-2020 02:37
Are you saying you can't install the Fitbit app on your new phone? If so, then I don't see a way for you to continue to use your fitbit.
Best Answer03-22-2020 05:47
03-22-2020 05:47
Load the Fitbit app onto the phone @SunsetRunner
Log into your Fitbit account on the new phone.
A user does not connect a Fitbit tracker to a phone but the tracker connects to their Fitbit account.
Log into your account, make sure your logging into the correct account and not creating a new account.
Your Fitbit app will see the tracker and show that it is connected to your account.
Now follow the steps to unlock that @SteveH. pointed to.
These steps will work unless you removed the tracker from your Fitbit account. If you did remove the tracker let us know.
