06-24-2019 12:49
06-24-2019 12:49
Hi,
I just got back from a one hour Vinyasa yoga class during which I activated the yoga exercise on my Versa. Now it turns out I only burnt 111 calories, which is highly disappointing. Earlier today I burnt 130 calories with a 20 minute walk. I've been told that Vinyasa should cause a higher calorie burn.
Has something gone wrong with my exercise app on my versa or is this rather correct?
Thanks!
06-24-2019 13:17
06-24-2019 13:17
You don't say how long your class was, but the key is your heart rate. Look at your heart rate during the class to judge calorie burn rate; compare that to heart rate while walking.
Best Answer06-24-2019 13:31
06-24-2019 13:31
Hi,
Thanks for your reply.
I did: it took one hour.
My heart rate wans't particulary high during the class. I was in the fat burn zone for only 9 minutes.
I don't know why this is, since it was a rather intense class and it felt like I really did an effort.
If Vinyasa yoga truely has this low effect, I will probably not do it again.
Best Answer06-24-2019 14:51
06-24-2019 14:51
I can't judge but, there certainly can be health benefits other than the number of calories burned.
Best Answer06-24-2019 14:55
06-24-2019 14:55
Of course there can be.
Except that I'm specifically searching for sports to burn calories.
Walking and running work just fine but yoga doesn't seem to do the trick.
06-24-2019 14:55
Was it set to yoga on your exercise app? Yoga isn't one of the default settings, but you can add it.
Best Answer06-24-2019 15:09
06-24-2019 15:09
I know. I added it. And it was set to yoga the entire course.
Best Answer06-24-2019 18:16 - edited 06-24-2019 18:17
Best Answer06-24-2019 23:09
06-24-2019 23:09
Indeed, it is flow yoga.
Well, my average heart rate during yoga was only 81 bpm indeed. And this is rather odd. A simple walk can raise my heartbeat up tot more than 100 bpm but planking and standing almost upside down on my hands for one hour while it's 30 degrees celcius doesn't have any effect on my heartbeat.
Best Answer08-16-2021 03:38
08-16-2021 03:38
Hi! Don’t give up on Yoga…. No idea where they came up with those calories! Look at the calories burned after the class- this is the accurate number. You also need to consider the muscle you’re building during these classes… muscle burns calories while resting. Lastly, yoga is mind, body, spirit- you’re practice “exercises” threefold 🙂
