03-07-2021 14:18
03-07-2021 14:18
Hi,
I’m wondering if anyone can help me gain some clarity around the estimated oxygen variation feature. I appreciate it’s not a diagnostic tool, I also understand that high variations are what are considered worth paying attention to. What isn’t very clear on researching is incredibly low levels (not variations). I noticed my green line is getting lower and lower, so while the variations are mostly good, the level is in quite a different place to usual. I’m just curious what this means. (It’s definitely not less stress 😂).
03-08-2021 04:59
03-08-2021 04:59
@Tee- Your screenshot isn't a good indicator of what is going on right now. I believe that the long, flat sections of the graph are places where your Fitbit couldn't collect data. You might have had your wrist in a position where you didn't have good contact. You can't draw any conclusions from this graph.
Laurie | Maryland, USA
03-08-2021 06:29
03-08-2021 06:29
03-08-2021 06:30
03-08-2021 06:30
Thanks. Yea, I’d figured that’s what the flat bits meant. I was more focused on how low the dips are, as they’re almost touching the bottom. Mine have been getting lower for weeks. Perhaps this wasn’t the best example shot. I just used the most recent one. Appreciate your answer.
